raymond008
Dec 26, 2021Aspirant
RBR20 ethernet backhual issue
Hi, I am trying to use a mix of 5G + ethernet backhaul setup for rbr20 system. I have 3 rbs20 satellite. I use rbr20 as access point mode. All my 3 satellites are working fine now t...
CrimpOn
Dec 26, 2021Guru - Experienced User
There have been posts describing an "ARP Storm" that sometimes happens when satellites are connected through a dumb switch. Apparently the storm continues for a minute or two and then ceases.
Does the Orbi stay at 100% CPU for an extended length of time?
raymond008
The 100% cpu is on my VPN router (tl-r600vpn), not the orbi unit. It situated the CPU and ended up knock out my network access until I unplug the satellite. I don't think it's related to the rbr20 unit at all ...
Here is my detail setup and connectivities:
ISP -> WAN -> tl-r600vpn -+- LanPort1 --> rbr20 -> 5G backhaul -> rbs20 (x2)
-+- LanPort2 --> tl-sg1024s -+-> gs724t -+-> tl-sg116 -+-> rbs20 (also connected through 5G backhaul at the time)
All my orbi units including rbr20 are on dhcp (i.e. dynamic IP assigned from the VPN router).
As you can see, I try to connect the main unit (rbr20) through multiple layer of switches to satellites.
I try to get a confirmatioin that will the above configuration works or not. Or I have to connect the tl-sg1024s
into the lan port of rbr20.
I wonder if I need to remove the satellite before I re-connect it through ethernet to avoid the ARP storm issue probably triggered by the dual path to the main unit. I haven't tried that yet ...
Thanks.
