raymond008
Dec 26, 2021Aspirant
RBR20 ethernet backhual issue
Hi, I am trying to use a mix of 5G + ethernet backhaul setup for rbr20 system. I have 3 rbs20 satellite. I use rbr20 as access point mode. All my 3 satellites are working fine now t...
Dec 26, 2021Guru - Experienced User
What switches is it?
Also, your diagram with the "+" doesn't say if that switch is plugged into the RBR unit or into your VPN router.
Make sure its to the RBR unit
raymond008
Is that the only way it will work?
The reason I try not to plug the switch to the rbr20 unit is try to avoid the wireless AP
bring down the entire network including the wired devices, e.g., during wifi reconfiguration.
Thanks.
