komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
MrBillAllen
Mar 25, 2019Guide
I'm having the exact same issue. I've reporduced it a couple of times.
Reboot router - factory reset
Remove power - factory reset
Power off/on - factory reset
RBR20
Firmware V2.2.1.210
Modem CM1100
- MrBillAllenMar 25, 2019Guide
I tried solution posted by michaelkenward but same result.
- michaelkenwardMar 25, 2019Guru - Experienced User
Thanks for the feedback.
Another possibility is to reflash the new firmware manually. Maybe it did not stick completely first time around.
I'll give that a try as soon as I can. I've opened a case with Netgear support and will also post result.
- mikevanocdnMar 25, 2019TutorJust bought my router system a week ago and having the exact same issue...if this doesn’t get fixed soon, I’m returning. My wife doesn’t know how to fix if I am not around and I am not going to waste my time whenever there is a power blip to fix this...life’s too short for this. Let me know if it gets fixed.
- FURRYe38Mar 25, 2019Guru - Experienced User
Might try a full manual re-load of the FW files on the system using a web browser. Then do a factory reset and setup from scratch, walk thru the setup wizard using a web browser. Do a back up of the configuration to file.
Then test to see if the setting presist or if the system resets if powered off and back on or thru a reboot.
mikevanocdn wrote:
Just bought my router system a week ago and having the exact same issue...if this doesn’t get fixed soon, I’m returning. My wife doesn’t know how to fix if I am not around and I am not going to waste my time whenever there is a power blip to fix this...life’s too short for this. Let me know if it gets fixed.- komradeMar 25, 2019Guide
So tried all the possible solutions in this thread so far to no avail.
Was previously on 2.1.3 (or something like that) and downloaded V2.3.0.28 and did a manual update through the GUI. On reboot, it went to factory settings.
Did the 30-30-30 power cycle, reconfigured everything, went to reboot, and lost all settings again.
I put a UPS on it for now just in case I have a small power outage, but still, incredibly frustrating to lose all settings on any sort of power loss or even software reboot.
