komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
MrBillAllen
Mar 25, 2019Guide
I tried solution posted by michaelkenward but same result.
michaelkenward
Mar 25, 2019Guru - Experienced User
Thanks for the feedback.
Another possibility is to reflash the new firmware manually. Maybe it did not stick completely first time around.
- MrBillAllenMar 25, 2019Guide
I'll give that a try as soon as I can. I've opened a case with Netgear support and will also post result.
