komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
Mar 25, 2019Guru - Experienced User
Might try a full manual re-load of the FW files on the system using a web browser. Then do a factory reset and setup from scratch, walk thru the setup wizard using a web browser. Do a back up of the configuration to file.
Then test to see if the setting presist or if the system resets if powered off and back on or thru a reboot.
