komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
mikevanocdn
Mar 25, 2019Tutor
Just bought my router system a week ago and having the exact same issue...if this doesn’t get fixed soon, I’m returning. My wife doesn’t know how to fix if I am not around and I am not going to waste my time whenever there is a power blip to fix this...life’s too short for this. Let me know if it gets fixed.
Mar 25, 2019Guru - Experienced User
Might try a full manual re-load of the FW files on the system using a web browser. Then do a factory reset and setup from scratch, walk thru the setup wizard using a web browser. Do a back up of the configuration to file.
Then test to see if the setting presist or if the system resets if powered off and back on or thru a reboot.
- komradeMar 25, 2019Guide
So tried all the possible solutions in this thread so far to no avail.
Was previously on 2.1.3 (or something like that) and downloaded V2.3.0.28 and did a manual update through the GUI. On reboot, it went to factory settings.
Did the 30-30-30 power cycle, reconfigured everything, went to reboot, and lost all settings again.
I put a UPS on it for now just in case I have a small power outage, but still, incredibly frustrating to lose all settings on any sort of power loss or even software reboot.
- FURRYe38Mar 25, 2019Guru - Experienced User
Try a manual download of the FW files and re-load the RBR again using a wired PC and IE11 or FF browser. After the FW is loaded, do one more factory reset and walk thru the setup wizard. Once setup. Back up the configruation to file.
Then test to see if the router retains the configuration by pulling the power. Back on.
IF the router doesn't retain the configuration, I would return the unit to place of purchase or ask NG for an RMA.
