komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
mikevanocdn
Mar 25, 2019Tutor
I’ll give this a try, but from what you said, looks like I don’t have the latest Firmware.
MrBillAllen
Mar 25, 2019Guide
I really believe it’s the reset “after” the firmware update that fixes the problem.
