komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
Mar 26, 2019Guru - Experienced User
Let us know if you need help getting Fw updated.
mikevanocdn wrote:
I’ll give this a try, but from what you said, looks like I don’t have the latest Firmware.
mikevanocdn
Mar 26, 2019Tutor
Looks like the firmware update with 30-30-30 reset worked. Thanks all for the help. Hopefully this doesn’t become a trend.
- FURRYe38Mar 27, 2019Guru - Experienced User
Glad that fixed it. You should be ok now. Probably an odd ball issue with yoru system. Haven't seen anyone else post about this.
Please mark your thread as solves so if others do see this, they can try this.
Enjoy. :smileywink:
