komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
Mixster6
Mar 28, 2019Aspirant
on V2.3.0.28 and had set it up a 4th time (no restore from backup, 30-30-30 reset, manual firmware upload). Seemed to work fine and past Sunday..boom..factory reset . So sick of this -
Just ordered a UPS for the main unit and maybe that'll help.
Mar 28, 2019Guru - Experienced User
I would contact NG about this and ask for an RMA. This should not be happening at all, with or with out a UPS. You may have a bad unit that needs to be replaced.
https://www.netgear.com/mynetgear/registration/login.aspx
