komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
Phardy
Mar 29, 2019Guide
I’m having the same issue.
Mar 29, 2019Guru - Experienced User
Try a FW update to v44 if you see it in the auto update on the routers web page. If thats not available, update to v28 which the files are available for download on NG support page. Factor reset after updating and setup from scratch.
