komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
MrBillAllen
Apr 05, 2019Guide
Just to follow up.
Experienced another power outage today and the system maintained the configuration. At this point I'm considering my issue resolved.
I'm running FW V2.3.0.28 which I downloaded from the site and installed manually through the GUI. After the firmware update I performed another factory reset and walked through the setup again.
Since then I have tested three times, rebooted, pulled the plug and rebooted. And finally the power outage today.
My system appears stable.
- FURRYe38Apr 05, 2019Guru - Experienced User
I wonder if you did the same thing for v44, would that continue to be stable on v44?
Thank you for letting us know.
MrBillAllen wrote:
Just to follow up.
- komradeApr 05, 2019Guide
Glad it's working now. Besure to save a backup configuration to file for safe keeping.
Enjoy. :smileywink:
