komrade
Mar 22, 2019Guide
RBR20 factory reset on reboot
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. ...
- Apr 05, 2019
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
Thefugitive87
Apr 13, 2019Tutor
I have the Rbr20 and Rbs20 on wired back haul. I have the current 2.3.1.44 on both and I am still loosing all setting with power loss. I just bought a ups to band aid this issue, but shouldn't be an issue at all.
MrBillAllen
Apr 14, 2019Guide
If you haven't performed a factory reset since your latest firmware upgrade I would;
Backup my config
perform a factory reset
That is what worked for me.
