CareerOppo
Dec 11, 2019Aspirant
RBR20 fail on setup
I've had a lot of Netgear products over the years and they've always delivered. But I bought a new RBR20 the other day which I picked up today. Using the factory SSID and password, trying to log in...
Dec 11, 2019Guru - Experienced User
So with a wired PC and Say IE11 or FF browser connected to the RBR and pressing the reset button in back for 15 seconds then release, can you walk thru the setup wizard found at 192.168.1.1 in the browser and complete the setup?
CareerOppo wrote:I've had a lot of Netgear products over the years and they've always delivered.
Using the factory SSID and password, trying to log in to WiFi on iPhone gives me "Incorrect password". Same thing on a Windows PC gives me "Can't connect to this network".
Wired internet works though.
Trying get into the admin page to try and fix the WiFi problem using default username and password just produces a neverending login loop both on Chrome and Edge.
Clicking Cancel during this loop sends me to password recovery but to do that, I have to enter the cities where I and my mother were born. Which I've never had the chance to input.
Netgear Suppport page says I bought the product in June (wrong) so I am not eligible for support.
Trying to register the router on MyNetgear gives me "This serial number is already registered to another customer". It's a new product!
Tried a factory reset, no change.
Sorry for venting a bit but this is my worst experience ever with a new electronic product.
Can you help?
- CareerOppoDec 11, 2019Aspirant
Pushing the reset button for 30 seconds worked. I tried 7-10 seconds earlier but apparently that wasn't long enough. So now I've been able to log on both to WiFi and to the admin pages. It still seems pretty buggy to me; I can't turn on the guest network and it randomly throws me out of the admin area every now and then. And it's clearly been owned by someone else. So I'll see if I keep it.
- FURRYe38Dec 12, 2019Guru - Experienced User
You might get the FW updated first on the RBR. Manually download the FW file for the RBS and RBR. Use a wired PC and web browser to apply the RBS first then RBR. You need only 15 second press on the reset button. Do this once more after the FW is applied on the RBR. Clear all browser caches and then setup from scratch. If you still noticed that the web pages and features are still not working, I would return the system and get another one. Ask for new if possible.
CareerOppo wrote:Pushing the reset button for 30 seconds worked. I tried 7-10 seconds earlier but apparently that wasn't long enough. So now I've been able to log on both to WiFi and to the admin pages. It still seems pretty buggy to me; I can't turn on the guest network and it randomly throws me out of the admin area every now and then. And it's clearly been owned by someone else. So I'll see if I keep it.
