echo92626
Mar 07, 2020Star
RBR20 Firmware HotFix Update not working
Your firmware website page shows a hotfix for ORbi RBR20 Firmware RBR20-V2.3.5.26. Downloaded both new Satellite and Router Firmware (RBS20-V2.3.5.36 & RBR20-V2.3.5.36) and attempted to install Manu...
Mar 07, 2020Guru - Experienced User
What FW version do you have loaded currently?
Try a different browser. IE11 or Firefox.
Be sure to upack the .zip file to reveal the actual FW files to be used as suggested....
echo92626 wrote:Your firmware website page shows a hotfix for ORbi RBR20 Firmware RBR20-V2.3.5.26.
Downloaded both new Satellite and Router Firmware (RBS20-V2.3.5.36 & RBR20-V2.3.5.36) and attempted to install Manually
through the web browser with the "Satellite" first since Automatic Download does not show a update function for either Router or Satellite and the firmware was rejected, saying wrong version.
Why is your firmware update not working?
- echo92626Mar 07, 2020Star
current FW: RBR20-V2.3.5.26
- FURRYe38Mar 07, 2020Guru - Experienced User
Try a different browser?
- echo92626Mar 08, 2020Star
Yes, tried Firefox and while that did allow me to update the Satellite to FW .36
...after Satellite restarted and I logged back in, it went back to FW .26.
It's as if the .36 HOT FIX does not apply to my RBR20, yet it shows as the lastest FW update online.
