GolfingArtist
Jun 04, 2020Tutor
RBR20 Firmware Update & Smart TV Problem
Yesterday I downloaded the latest firmware update (Router Firmware Version V2.5.1.16) and after doing the update my Samsung TV is connected to my Orbi Wireless Router / Mesh yet cannot get to the int...
- Jun 06, 2020
Glad that worked. Mark your thread as solved.
Enjoy.
GolfingArtist
Jun 04, 2020Tutor
My internet service is Xfinity / Comcast and my cable modem is a Netgear Nighthawk CM1150V.
Jun 04, 2020Guru - Experienced User
Affter the reset,
- GolfingArtistJun 04, 2020Tutor
Do I do that via the Orbi App?
- FURRYe38Jun 04, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings- GolfingArtistJun 04, 2020Tutor
Thanks will try tomorrow when I have more time.
