GolfingArtist
Jun 04, 2020Tutor
RBR20 Firmware Update & Smart TV Problem
Yesterday I downloaded the latest firmware update (Router Firmware Version V2.5.1.16) and after doing the update my Samsung TV is connected to my Orbi Wireless Router / Mesh yet cannot get to the int...
- Jun 06, 2020
Glad that worked. Mark your thread as solved.
Enjoy.
Jun 06, 2020Guru - Experienced User
Let us know how this turns out.
GolfingArtist
Jun 06, 2020Tutor
I purchased for $ 85 from best Buy:
NETGEAR - Powerline AC1200 Gigabit Ethernet Adapter (2-pack)
Model:PL1200-100PAS
SKU:4002029
It worked great and took 5 minutes set up. I was able to restore internet access to my Smart TV.
John
- FURRYe38Jun 06, 2020Guru - Experienced User
Enjoy.
- michaelkenwardJun 06, 2020Guru - Experienced User
Model:PL1200-100PASSKU:4002029It worked great and took 5 minutes set up. I was able to restore internet access to my Smart TV.That's good. Glad I wasn't completely mad. I have never looked back since going Powerline.
There is no reason not to have PL1200 plugs, with their Gbps Ethernet, but unless it is a new smart (ho ho) TV, it will happily work with slower and cheaper 100 Mbps plugs. Streaming doesn't need Gbps. But, as I say, nothing lost.
There are a few wrinkles with Powerline, not helped by Netgear's failure to provide supporting software. No need to worry about that until you have problems. But come back if there are any.
