OrbiOwner9904
Dec 30, 2020Follower
RBR20 Firmware update not showing up in Check update
I got an email from Netgear that there is a security update for RBR20 (currently on version V2.5.1.16). When i go to the IOS app or the Web browser there is no firmware update showing up. I checked N...
fmalloy
Dec 30, 2020Luminary
You'd also have to visit the RBS20
CrimpOn wrote:
OrbiOwner9904 wrote:I woudn't worry about this normnally but considering this is a security update, i would like to update. My confirguration is below:
In the absence of a formal method to update firmware, the only thing a user can do is download the new firmware from the Netgear support site, unpack the "img" files from the "zip" files, log onto the Orbi units and select the Manual Update tab. There is a general feeliing that the satellite should be updated first.
If you have RBS20 satellites you'll want to visit the RBS20 Firmware and Downloads web page, and download the .zip for that. The version for RBS20 is 2.6.1.38 (new RBR20 is 2.6.1.36).
Personally, after what I have been reading on this forum (new problems with new firmware, also flat-out bricked routers) I'm very nervous about updating firmware, unfortunately. The fact that you have to manually update the satellites first, then the router puts too much on the user, and is quite frankly, ridiculous.
My father in law has a Google mesh system and it just updates itself and the satellites silently and automatically. No downloading of multiple .zip files from multiple locations, no worry about order of installation. How it should be.
Dec 30, 2020Guru - Experienced User
Updating the RBS first then RBR is mostly for manual updates where users download the FW files and apply those files to the RBS web page then RBR. I have tried recently with v102 and let the RBR update the RBS as well and it does work. So using the RBRs web page and using the UPDATE ALL function seems to work for that function.
