OrbiOwner9904
Dec 30, 2020Follower
RBR20 Firmware update not showing up in Check update
I got an email from Netgear that there is a security update for RBR20 (currently on version V2.5.1.16). When i go to the IOS app or the Web browser there is no firmware update showing up. I checked N...
Dec 30, 2020Guru - Experienced User
Updating the RBS first then RBR is mostly for manual updates where users download the FW files and apply those files to the RBS web page then RBR. I have tried recently with v102 and let the RBR update the RBS as well and it does work. So using the RBRs web page and using the UPDATE ALL function seems to work for that function.
fmalloy
Dec 30, 2020Luminary
It's posts like this that make me reluctant to update firmware:
- vajimDec 30, 2020Master
fmalloy wrote:It's posts like this that make me reluctant to update firmware:
So stop
- fmalloyDec 30, 2020Luminary
So stop
Sure, but then I miss out on the security update and any other fixes, like the issue I'm having where WiFi speed slows after x number of days.
- vajimDec 31, 2020Master
fmalloy wrote:
So stop
Ok. If you believe that there are others here you should join.
