oceanaveprops
Dec 27, 2023Aspirant
RBR20 guest network password keeps dropping
See a bunch of others with a similar issue but other models. The guest network password keeps dropping from the settings when entered and applied. The guest network then has an open network even th...
oceanaveprops
Thank you. went to that url and logged into site. however, not sure where to go from there in order to see my ORBI settings and make the updates you recommended.
Please provide further details or if I'm in the wrong area or site.
Thank you.
CrimpOn
Dec 27, 2023Guru - Experienced User
Guest network is described on page 80 of the RBR20 user manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
