oceanaveprops
Dec 27, 2023Aspirant
RBR20 guest network password keeps dropping
See a bunch of others with a similar issue but other models. The guest network password keeps dropping from the settings when entered and applied. The guest network then has an open network even th...
oceanaveprops
Dec 29, 2023Aspirant
Thank you. There is no login page on the orbilogin.com site based on your recommendations. I can log into the site using my netgear info but other than that I do not see anywhere there is a user admin and/or password to enter to access the router info you mentioned.
Please assist if possible. Am I in the right site? area/link of the site?
Thank you.
CrimpOn
Dec 29, 2023Guru - Experienced User
When users are connected to the Orbi, using either an Ethernet cable or via WiFi, and opens a web browser to http://orbilogin.net , the router intercepts the URL and connects the web browser to the Orbi router web administration, which pops up a login box asking for User Name and password.
If the user is not connected to the Orbi system, then what comes up is a page at Netgear's web site talking about how to Login & Setup an Orbi system.
Are you connected to the Orbi system when trying to use a web browser to reach http://orbilogin.net ?
