WirelessViking's avatar
Jan 13, 2021
RBR20 instability after 2.5.1.16->2.6.1.36 upgrade
As stated in the headline, I've just upgraded my RBR20 from 2.5.1.16 tpo 2.6.1.36 and have since experienced a lot of instability on my wireless network. Connectivity to core internet services is very "on and off", seems to dip for a bit and then come back.
Have two RBS20 satellites with wired backhaul. These are both brought up to 2.6.1.38.
Others with similar problems?
Considering a downgrade, but thought it would be good to have the latest security patches in production..
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)?
    • WirelessViking's avatar
      WirelessViking
      No factory reset and setup from scratch done. Would it be possible to do that in a simple way, like for example backing up the config and reloading that after factory reset? Configuring everything again would be really tedious..
      Distance between router and satellites is roughly 20m (60ft?). But they are on wired backhaul.
      • FURRYe38's avatar
        Yes you can back up to the config file. I would test the system out after the reset and setup first from scratch and test initially, then apply the backup config file after making sure you symtoms have changed.
        Are the RBS directly wired to the RBR or is there a LAN switch in between?
