WirelessViking
Jan 13, 2021Aspirant
RBR20 instability after 2.5.1.16->2.6.1.36 upgrade
As stated in the headline, I've just upgraded my RBR20 from 2.5.1.16 tpo 2.6.1.36 and have since experienced a lot of instability on my wireless network. Connectivity to core internet services is ver...
Jan 13, 2021Guru - Experienced User
Yes you can back up to the config file. I would test the system out after the reset and setup first from scratch and test initially, then apply the backup config file after making sure you symtoms have changed.
Are the RBS directly wired to the RBR or is there a LAN switch in between?
vajim
Jan 13, 2021Master
Aren't there reported problems with 2.6.1.36?
- WirelessVikingJan 13, 2021Aspirant
vajim wrote:Aren't there reported problems with 2.6.1.36?
Don't know.... Anyone?
- vajimJan 13, 2021Master
The search results has several with negative comments
- MainerH55Jan 13, 2021AspirantSorry, no problems here. I haven't even rebooted it once since installing the firmware weeks ago.
