Rookshaw
Aug 11, 2022Aspirant
RBR20 Internet drops after firware update
A few weeks ago I updated my RBR20 and satellites to the newest available firmware (2.7.4.24). Since then we lose our internet connection 4-5 times a day, but only for about 30seconds - 1.5minutes a...
Aug 11, 2022Guru - Experienced User
What CAT# lan cable are you using between the RBR and modem?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- RookshawAug 14, 2022Aspirant
Hello! Thank you for your reply (sorry for the delay in responding).
To answer your questions:
I am currently running firmware version: 2.7.4.24
The modem is an Arris TM1602A
Cable is a CAT 6
I have powered off the modem for over 1 minute and powered it back on since the last update (the ISP even had me do this an additional time when I was on the phone with them).
I had performed a restart in the sequence you suggested and it did not improve our issue.
I have not performed a factory reset and setup from scratch since the FW update. Is this recommended?
Thank you!
