Rookshaw
Aug 11, 2022Aspirant
RBR20 Internet drops after firware update
A few weeks ago I updated my RBR20 and satellites to the newest available firmware (2.7.4.24). Since then we lose our internet connection 4-5 times a day, but only for about 30seconds - 1.5minutes a...
Aug 11, 2022Guru - Experienced User
What CAT# lan cable are you using between the RBR and modem?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Rookshaw
Aug 14, 2022Aspirant
Hello! Thank you for your reply (sorry for the delay in responding).
To answer your questions:
I am currently running firmware version: 2.7.4.24
The modem is an Arris TM1602A
Cable is a CAT 6
I have powered off the modem for over 1 minute and powered it back on since the last update (the ISP even had me do this an additional time when I was on the phone with them).
I had performed a restart in the sequence you suggested and it did not improve our issue.
I have not performed a factory reset and setup from scratch since the FW update. Is this recommended?
Thank you!
