Rookshaw
Aug 11, 2022Aspirant
RBR20 Internet drops after firware update
A few weeks ago I updated my RBR20 and satellites to the newest available firmware (2.7.4.24). Since then we lose our internet connection 4-5 times a day, but only for about 30seconds - 1.5minutes a...
KevinLiT
Aug 15, 2022NETGEAR Moderator
Hello Rookshaw,
Welcome to the NETGEAR Community!
Please perform a factory reset on your RBR20 using the recommended 30/30/30 reset method.
Best,
Kevin
Community Team
Chandroo
Sep 25, 2022Initiate
I’m facing the same issue of network disconnection. I rolled back to 2.6.x firmware and tried - same problem. Did a factory reset with a wired PC connection, however losing network information continuously. I’m unable to setup Orbi itself now. Any ideas?
- ChandrooSep 26, 2022InitiateUpdate on the network drop issue. Tried factory reset - still saw network disconnection. Basically the router was dropping it’s IP address very frequently. As a last resort tried to use a different power adaptor. This time the IP address stuck, no network disconnection was noticed. Connected through wireless to the ORBI and went through the setup with no issues. During setup the firmware also got updated to the latest. The setup has been up and running for few hours now. So looks like the different power adaptor did the trick. Hope this helps someone too
- AerialAssault23Dec 06, 2022Aspirant
I have the exact same setup and am having the exact same problem. I did not see this before creating my own post. Did you just use the power cord from a satellite?
Correction, mine is RBR50 but same modem, same symptoms. I am currently having isp confirm there are no configuration/compatibility issues but will then try a different power adapter.
