Goldentwig
Aug 26, 2020Follower
RBR20 just randomly dropping connection!
I am so frustrated! We have the Orbi RBR 20 mesh network set up and it has randomly gone offline with no explanation at least 4 times in the past 9 days. My kids are trying to do online virtual school...
Aug 26, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
