drussi
Aug 29, 2023Aspirant
RBR20 keeps dropping internet connect and flashing magenta
For the last couple weeks my RBR20 keeps dropping the internet connection and flashing magenta. If I reboot the Orbi connected to my ISP then the internet comes back for a while. I've verified if I j...
Aug 29, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
If you see pink on the top ring LED, means the RBR has lost the connection to the ISP modem or the ISP modem is not longer getting data to the RBR. https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Something to check with the ISP with to ensure there modem/ONT is working and if they notice anything during these time frames when this happens.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
drussi
Aug 30, 2023Aspirant
FW: V2.7.4.24
ISP Router\Modem: worldwide packets lightningedge 38SFP
I've rebooted all the devices, swapped the network cable from the Orbi to the ISP router including a different port and it ran for a while hitting this twice in the last 24 hours. Rebooting the Orbi brought it back agai.
- FURRYe38Aug 30, 2023Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- drussiAug 30, 2023Aspirant
The modem is owned by the ISP and so I have no access to it. It doesn't run wifi so that isn't a problem. The Orbi has been working fine for a couple years in the same configuration until the last couple of weeks so trying to figure out what is going on. Rebooting the Orbi seems to resolve it for some number of hours.
- FURRYe38Aug 31, 2023Guru - Experienced User
Have the ISP check there services up to there modem.
Ask them to put the RBR in the modems DMZ.
