wmickens
Nov 10, 2020Aspirant
RBR20 lag spikes
This is very frustrating. I have an Orbi RBR20 that when I ping the router itself from two different machines (Linux and Windows) and a cell phone i get occasional lag spike that ranges from 60ms to ...
Nov 10, 2020Guru - Experienced User
What modem are you connected to?
What firmware is on the router? And the satellite(s)?
Have you tried turning off the satellites and seeing if you get the ping spikes just running the router?
wmickens
It is a Spectrum modem but I'm only pinging the internal IP address.
| Model Name | Device Name | Current Version | Status | |
| Router | RBR20 | RBR20 | V2.5.1.16 | |
| Satellite | RBW30 | Sat-one | V2.6.1.6 |
With just the router I was getting the same spikes.
Here is a snippet of the ping to the router:
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=18ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=10ms TTL=64
Reply from 192.168.1.1: bytes=32 time=7ms TTL=64
Reply from 192.168.1.1: bytes=32 time=12ms TTL=64
Reply from 192.168.1.1: bytes=32 time=323ms TTL=64
Reply from 192.168.1.1: bytes=32 time=8ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=16ms TTL=64
Here is the stats of the ping I just ran:
Ping statistics for 192.168.1.1:
Packets: Sent = 579, Received = 579, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 1796ms, Average = 33ms
- plemansNov 10, 2020Guru - Experienced User
If you're getting this with the satellite powered off, it isn't the satellite.
have you tried a factory reset on the router?
when you reinstall it, do a clean install (not from backup).
Make sure to leave traffic monitoring, access control, parental controls all disabled.
- wmickensNov 11, 2020Aspirant
Did a factory reset and left all of the mentioned options disabled...yet I'm still having the same issues. In some cases it is even worse:
Reply from 192.168.1.1: bytes=32 time=11ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1067ms TTL=64
Reply from 192.168.1.1: bytes=32 time=14ms TTL=64
Reply from 192.168.1.1: bytes=32 time=19ms TTL=64
Reply from 192.168.1.1: bytes=32 time=17ms TTL=64
Reply from 192.168.1.1: bytes=32 time=25ms TTL=64
Reply from 192.168.1.1: bytes=32 time=28ms TTL=64
Reply from 192.168.1.1: bytes=32 time=13ms TTL=64
Reply from 192.168.1.1: bytes=32 time=9ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64Ping statistics for 192.168.1.1:
Packets: Sent = 1324, Received = 1217, Lost = 107 (8% loss),
Minimum = 1ms, Maximum = 1340ms, Average = 18msNot worried about the lost packets as the running ping was done while the router was being set up. The maximum should not be over 1300ms just for pinging the router internally.
- plemansNov 11, 2020Guru - Experienced User
Are you doing these tests over wireless or wired?
