CHrisFrench
May 18, 2019Aspirant
RBR20 Latest Firmware 2.3.1.58 + Wifi Card Qualcomm Atheros AR9485WB-EG Incompatible
Hello Guys
One laptop on Windows 10 Home Edition with wifi Card Qualcomm AtherosAR9485WB-EG is not able to connect to Orbi Wifi after latest firmware of RBR20 system
Thanks
- Jun 03, 2019
Thanks Blanca
It is connecting now
To be honest I don't know the exact reason why...and I don have time to dig deeper on this
Best Regards
CrimpOn
May 25, 2019Guru - Experienced User
CHrisFrench wrote:One laptop on Windows 10 Home Edition with wifi Card Qualcomm AtherosAR9485WB-EG is not able to connect to Orbi Wifi after latest firmware of RBR20 system
Is it correct to assume that this Windows 10 computer was connected to Orbi WiFi before the firmware update? On the Advanced Tab, under Security, Access Control, there is a table showing devices that are "Allowed devices not currently connected." Does the MAC address for this device appear in that table?
CrimpOn
On my Orbi, I have to scroll down the page to find this table. Also, there is a table (still farther down) of "blocked devices."
- CHrisFrenchMay 26, 2019Aspirant
Thanks for the info but that is nt the case as the Orbi is acting as AP (not in router mode)
- CrimpOnMay 26, 2019Guru - Experienced User
Oh, my. Since those tables list only MAC address for allowed and not allowed, I had thought they work in AP mode. The router that assigns IP addresses may have Access Control?
It connected over WiFi before the Orbi firmware update, and now does not connect?
Does it connect over ethernet?
What messages does Windows report about the failure to connect?
Does Windows 10 have Event logs with more detailed explanation of what is going wrong?
A Google search turned up suggestions about WiFi connections, including several specific to Atheros cards.
