krishdhar
Apr 11, 2021Tutor
RBR20 latest firmware update V2.6.2.104
I just updated the firmware on RBR20 to V2.6.2.104 and now I have some devices have internet and others don't. Don't know why some devices cannot get internet even though they connect to wifi and I c...
chrisgoodson1
Apr 15, 2021Aspirant
I have unplugged and rebooted (hard and soft) on numerous occaisons. But I will say that I have never left it unplugged for as long as 12 minutes. That seems like an excessively long time. I've left it unplugged for probably 30 seconds to a minute. However, I decided to downgrade the router firmware last night and try that. I'm now running V 2.6.1.36 on the router. The satellites (3) are still running V 2.6.2.104. So far, I haven't run into the issue, but I will let it run for a couple of days before I declare victory. :)
Ha_Ku_Na
Apr 15, 2021Luminary
chrisgoodson1 wrote:... I have never left it unplugged for as long as 12 minutes. ...
Sorry, this was typo, I meant 1-2 minutes :smileysurprised:
I own a RBK50 and never changed the defaults for traffic-meter and NTP, and I was not affected by the bug(s) in the last available FW. But I have tested it as I saw the issues here and activated traffic-meter and this broke my network within less than 1 day.
Anyway, lets hope your system is back stable.
- Ha_Ku_NaApr 15, 2021Luminary
FURRYe38 wrote:Ha_Ku_Na Just curious, when you activated TM, how did you configure it? I set mine for No Limit and just reporing data flow. Haven't seen any issues. Though I'm using the beta now. :smileyembarrassed:
As I remember, I just enabled it without set any limits and not restartet the RBR/S's.
On the next morning, a lot of the connected devices were no longer working as expected.
Afterwards I've done a factory reset and reloaded the config from file.Btw, I also asked a week ago one of the moderators for the beta but got no response until now ... any chance you can provide the files for RBR/S 50 ?
- FURRYe38Apr 15, 2021Guru - Experienced User
Ok, I set No Limit on the RBR, applied the setting and rebooted the RBR or I may have powered if OFF for 15 seconds then back ON. Did not see any problems with any devices after that.
Also did not load a saved configuration from file either.
