Street420
Aug 05, 2021Aspirant
RBR20 Losing internet connection about 1-2 times / day
Until recently router has been very stable, for about the last 1.5 weeks I lose (only) the internet connection from the router. Can still connect fine to the router from devices, but all devices repo...
Aug 05, 2021Guru - Experienced User
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- Street420Aug 05, 2021Aspirant
I'm not looking for the canned response. I already read though those posts and it appears that none of that ever helped anyone.
Some items that I mentioned previously and some additional feedback:
1. router worked flawlessly until 1.5 weeks ago.
2. No configurations were changed
a. with the exception of the updated firmware - which made no difference
b. update via telnet to the lease time (I really had high hopes for this one)
3. no additional devices have been introduced
4. Lan port also has no internet access (meaning it is not just a wireless thing)
5. Connectivity via lan or via wifi to the router is just fine, only the connection between the router and the cable modem is lost
6. Tried a different ethernet cable, and checked to make sure the cable was not loose
7. Geographically isolated from neighbors and other wifi connections (mine is the only one in range)
8. Satellites are unplugged to rule out some problem with them
9. Problem fixes itself within 5 minutes or so without intervention - no unusual log entries
I have no ability to access my modem's diagnostic / log info, but my ISP has confirmed that they see no outages to the actual internet. I was able to plug devices directly into the modem and they worked right away. It does not have any model info on the modem itself, provided by Charter Communications now Spectrum.
- FURRYe38Aug 05, 2021Guru - Experienced User
Then you'll need to contact NG support for there help and support.
Good Luck. - gbjacksonAug 14, 2021Apprentice
I'm having the exact same issue with an RBR50. Tried everything plus replacing the cable from the modem to the router, but it's still a daily occurrence (usually around the same time of day - llate afternoon CST).
- FURRYe38Aug 14, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless SettingsTry disabling the following and see:
Armor, Circle, Traffic Meter.Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
