Street420
Aug 05, 2021Aspirant
RBR20 Losing internet connection about 1-2 times / day
Until recently router has been very stable, for about the last 1.5 weeks I lose (only) the internet connection from the router. Can still connect fine to the router from devices, but all devices repo...
Aug 16, 2021Guru - Experienced User
Any progess on this?
gbjackson wrote:
I'm having the exact same issue with an RBR50. Tried everything plus replacing the cable from the modem to the router, but it's still a daily occurrence (usually around the same time of day - llate afternoon CST).
gbjackson
Aug 17, 2021Apprentice
Not yet. There's been no change on the ISP end or with the modem that the Orbi is attacehd to. It's not base or satellite location; again, those have never changed, are > 30 feet apart, and when connected, they flash blue. House is 2,300 square feet, base on floor 1, satellites on floor 2 and in basement. No new networks in the neighborhood, that I can see.
Have cycled everything off completely many times. Still having to reboot most days. I don't recall this happing before the 2.7.3.22 firmware upgrade, but not about that.
- FURRYe38Aug 17, 2021Guru - Experienced User
That happens when you turn OFF one RBS? Or both? Does the RBR continue to loose the internet connection?
2300sq ft maybe too small of a home size for two RBS.
- gbjacksonAug 17, 2021Apprentice
It hasn't been a problem in over 2 years of running 2 base stations - the house is from the 1930s and its construction is such that running with a single satellite was not adequate once we remodeled the basement and turned it into additional living space.
Id do a full factory reset and setup from scratch on the RBS and RBR. If this doesn't resolve this, revert back to prior working version...
