LLWLLL
Dec 17, 2020Aspirant
RBR20 Magenta, Satelline good
I've reset/rebooted the router two times, still magenta - the app shows that it's disconnected/offline....however the satellite is fine. Do I give up and buy something new? Firmware Version V2.5.1....
CrimpOn
Dec 18, 2020Guru - Experienced User
LLWLLL wrote:I've reset/rebooted the router two times, still magenta - the app shows that it's disconnected/offline....however the satellite is fine.
Do I give up and buy something new? Firmware Version V2.5.1.16 no updated required....? we purchased 1 1/2 years ago
any suggestions?
As vajim pointed out, the "app" is almost useless for diagnosing problems. I notice that the post did not start out with a description of "what is not working." There have been many posts about the "app" saying the router was magenta, but that "everything works fine."
I am guessing that you looked at the app because "something was amiss"???
