pushkin69's avatar
pushkin69
RBR20 magenta with AT&T internet
Hi folks, seeing a weird issue with my parents’ Orbi. Their ISP is AT&T and I’ve turned off all wifi radios on their router. I connected the Orbi router to it, and put it into AP mode. And things work well for a while (weeks). Then out of nowhere, the Orbi router seems to lose internet - pages stop loading, the router shows as Magenta on the Orbi mobile app, while the satellites remain green. Restating the Orbi router once or twice seems to resolve the issue. I thought it may be an intermittent issue with the ISP, but the issue doesn’t seem to occur if I just use the AT&T router without Orbi. Am I missing a setting somewhere? I have the same setup at my own home but with verizon Fios, and never get these issues.
  • FURRYe38's avatar
    What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? If so,
    This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • pushkin69's avatar
      pushkin69
      Orbi firmware 2.5.1.16. AT&T router is Pace Plc 5268AC. And yeah I’ve already done option 3, as per my original message.
      • FURRYe38's avatar
        Be sure your using the WAN port on the RBR for the connection to the ISP modem.
        Be sure it's getting a good IP address from the ISP modem.
        Be sure your using a good quality LAN cable. CAT6 is recommended.
        Power OFF both ISP modem and RBR for 30 seconds, then back ON with the modem first then RBR.
        Try settting a static IP address ON the RBR for AP mode.
