Firerosie
Mar 30, 2021Follower
RBR20 mesh with 2 satellites. Since Firmare update 2.6.2.104 troubles
Has anyone experienced any problems since the latest Fireware update 2.6.2.104? My internet now goes out 2 -6 times a day since update. Contacted internet provider and have re-booted both Modem a...
btgrant
Apr 05, 2021Tutor
FURRYe38 wrote:Next time, try a factory reset and setup from scratch after loading new FW if you encounter problems. Many problems are solved by a reset.
Good Luck.
I figure that doing the firmware rollback would be less involved than a factory reset. In your experience, is doing a factory reset relatively trivial as long as you've got a backup of the router's configs? Or is it advised to reconfigure the router by hand after a factory reset?
Thanks!
Apr 05, 2021Guru - Experienced User
I recommend trying both with a saved configuration then one with from scratch if problems are seen after the backup is used. Sometimes older saved backups can still introduce problems from prior versions of FW. I recommend if updating FW and no issues are found, save off a new backup. If problems are seen, factory reset and setup from scratch, if no problems are seen after the reset, then save off a new backup configuration to file.
- vajimApr 05, 2021Master
FURRYe38 wrote:I recommend trying both with a saved configuration then one with from scratch if problems are seen after the backup is used. Sometimes older saved backups can still introduce problems from prior versions of FW. I recommend if updating FW and no issues are found, save off a new backup. If problems are seen, factory reset and setup from scratch, if no problems are seen after the reset, then save off a new backup configuration to file.
the trick is the 'problems'
best to wait and let the edge people try the new firmware out before you jump in the pool
- btgrantApr 06, 2021Tutor
I installed 2.6.1.x on both the router and the sattelites yesterday and nothing has improved. I saved versions of the configs from both before and after rolling back so I guess I'll be trying the factory reset next.
