rich1233211
Dec 21, 2019Follower
RBR20 Most Stable Firmware?
I am currently on V2.1.4.16. Without getting into it, I setup orbi at my family home and now that I come and visit for holidays I notice the wifi is total garbage. Satelites keep daisy chaining incor...
Dec 21, 2019Guru - Experienced User
I
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Lets try some troubleshooting first before deciding to update FW?
