rich1233211
Dec 21, 2019Follower
RBR20 Most Stable Firmware?
I am currently on V2.1.4.16. Without getting into it, I setup orbi at my family home and now that I come and visit for holidays I notice the wifi is total garbage. Satelites keep daisy chaining incor...
emma5
Mar 14, 2020Aspirant
rich1233211 wrote:I am currently on V2.1.4.16. Without getting into it, I setup orbi at my family home and now that I come and visit for holidays I notice the wifi is total garbage. Satelites keep daisy chaining incorrectly and frequent wifi cut outs and super slow speeds. fences What is the most stable FW you guys have had in your experience?
How did you resolve this, please let me know.
Thanks
Emma
- FURRYe38Mar 15, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Thanks
Emma
