rich1233211
Dec 21, 2019Follower
RBR20 Most Stable Firmware?
I am currently on V2.1.4.16. Without getting into it, I setup orbi at my family home and now that I come and visit for holidays I notice the wifi is total garbage. Satelites keep daisy chaining incor...
emma5
Mar 14, 2020Aspirant
rich1233211 wrote:I am currently on V2.1.4.16. Without getting into it, I setup orbi at my family home and now that I come and visit for holidays I notice the wifi is total garbage. Satelites keep daisy chaining incorrectly and frequent wifi cut outs and super slow speeds. fences What is the most stable FW you guys have had in your experience?
How did you resolve this, please let me know.
Thanks
Emma
Mar 15, 2020Guru - Experienced User
Thanks
Emma
