UserUserUser
Jul 23, 2020Aspirant
RBR20 NAS only visible near satellite it's plugged into
Folks, My Seagate network storage (connected to one of the satellites via Ethernet cable) is perfectly recognized and working, but only if I'm in the range of that satellite. It doesn't show on t...
Jul 24, 2020Guru - Experienced User
What happens if you connect the NAS to the RBR and then connect to the RBS? Can you still see the NAS then?
UserUserUser
Jul 24, 2020Aspirant
Well, I don't see the firmware version I just posted - just in case it got lost: the firmware version is v2.5.1.16
- FURRYe38Jul 25, 2020Guru - Experienced User
IF this doesn't change anything, I would make contact with NG support about this.
