5ft24dave
Sep 08, 2021Aspirant
RBR20 network dropping
2 years ago I purchased the RBR20 witrh a RBW30 satellite. worked great. About a year ago, a firmware upgrade was released that "fixed" a reported security issue with DNS. I loaded that firmware (...
Sep 08, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- 5ft24daveSep 08, 2021Aspirant
The router is the xfinity supplied technicolor brand 1.2Mbps gateway, model CGM4331COM, with Wifi disabled so I don't get interference, hardwired to the RBR20 There is no model number on it and only the MAC addrwess, serial etc on the label
House is 2500 sq/ft 2 story.
Distance to the first satellite is approx 45 feet. 2nd is about the same and the 3rd is about 65 feet. Router is on the bottom floor near the bottom of the staircase. 1st sat is at the top of the staircase, 2nd is on the bottom level and 3rd is upstairs about 20 ft from the stop of the stairway. Direct line of site to the lower level satellites, line of site between the 2 upstairs satellites.
Just re-ran a site survey to see if anyone that has recently moved in was on the same channels... 2.4G is channel 6, as we are the only house on the survey using it and 5ghz is 48 for the same reason.
Beamforming, MIMO and WMM are enabled, fast roaming and IPV6 are disabled (always has been this way)
Armor, Circle, Traffic Meter, Daisy Chain have never been enabled, coexistence has always been at 40MHz as well.
Every firmware change I have done I have always done a factory reset and reconfigure, the last 2 times I didn't load my backup, I only manually configured it to eliminate anything in the backup that may have been an issue.
it always works on the older firmware without any issues, however now, it will not stay on the manually flashed older firmware. Within an hour or so of rolling it back and reconfiguring the whole system, it appears the satellites update themselves, then force the router to upgrade. once it is on the 2.7.3.22 FW, the network goes to hell again
Signal levels on all 3 satellites to the router are between -42 and -48dbm
As I said, it did this after upgrading the first time, and I rolled it back and all was good. at the time i only had the RBW30 satellite. Since I added the 2 RBS20 satellites, it has forced the RBR20 to the latest FW which causes the issues again. with the 2 RBS20's powered off, I ran the old firmware for 2 days without a single issue. Within a couple hours of powering the RBS20's on, the RBR20 was forced to the latest FW.
I'm an IT tech and have years of experience and training in networking, ethernet and wireless. that is why I did the site survey when I first installed the system and again when the issues cropped up.
Again, this is directly related to FW because with no other changes, the old FW doesn't have a single issue. the latest, which now it updates itself to every time, has constant issues. Very Frustrating
- FURRYe38Sep 08, 2021Guru - Experienced User
Possible that your ISP modem/gateway is causing this as well. It's commended that if you have a external router, that the ISP modem, if it has a built in router, be bridged. If not, try setting the RBRs IP address it gets from the gateway router into it's DMZ.
Another configuration to try is to leave the modem in router mode and change the RBR to AP mode and see if the problem continues or not.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou can downgrade FW as well to last working version that worked for you on the Orbi system.
this config has worked for almost 2 years without any issue except the original dropping of network connections when I upgraded the fw. since then, when I rolled the FW back, it has had zero issues.
when I load the earlier FW the issues are gone, however, as I said, within an hour or 2 of rolling the satellite and RBR20 firmware back to working versions, the system AUTOMATICALLY updates the FW to the latest version again, and I can tell because I start getting the dropped connections again. so if you have a way to keep it from automatically upgrading the FW, please let me know because the FW is the issue.
Also, as I said, and it appears my post got skimmed over and not completely read, the Wifi on the Cable modem has always been disabled.
for emphasis, it works as it should on the older FW, it upgrades itself without notifying or prompting me. if I could block that action, I would have a working nnetwork again
