5ft24dave
Sep 08, 2021Aspirant
RBR20 network dropping
2 years ago I purchased the RBR20 witrh a RBW30 satellite. worked great. About a year ago, a firmware upgrade was released that "fixed" a reported security issue with DNS. I loaded that firmware (...
5ft24dave
The router is the xfinity supplied technicolor brand 1.2Mbps gateway, model CGM4331COM, with Wifi disabled so I don't get interference, hardwired to the RBR20 There is no model number on it and only the MAC addrwess, serial etc on the label
House is 2500 sq/ft 2 story.
Distance to the first satellite is approx 45 feet. 2nd is about the same and the 3rd is about 65 feet. Router is on the bottom floor near the bottom of the staircase. 1st sat is at the top of the staircase, 2nd is on the bottom level and 3rd is upstairs about 20 ft from the stop of the stairway. Direct line of site to the lower level satellites, line of site between the 2 upstairs satellites.
Just re-ran a site survey to see if anyone that has recently moved in was on the same channels... 2.4G is channel 6, as we are the only house on the survey using it and 5ghz is 48 for the same reason.
Beamforming, MIMO and WMM are enabled, fast roaming and IPV6 are disabled (always has been this way)
Armor, Circle, Traffic Meter, Daisy Chain have never been enabled, coexistence has always been at 40MHz as well.
Every firmware change I have done I have always done a factory reset and reconfigure, the last 2 times I didn't load my backup, I only manually configured it to eliminate anything in the backup that may have been an issue.
it always works on the older firmware without any issues, however now, it will not stay on the manually flashed older firmware. Within an hour or so of rolling it back and reconfiguring the whole system, it appears the satellites update themselves, then force the router to upgrade. once it is on the 2.7.3.22 FW, the network goes to hell again
Signal levels on all 3 satellites to the router are between -42 and -48dbm
As I said, it did this after upgrading the first time, and I rolled it back and all was good. at the time i only had the RBW30 satellite. Since I added the 2 RBS20 satellites, it has forced the RBR20 to the latest FW which causes the issues again. with the 2 RBS20's powered off, I ran the old firmware for 2 days without a single issue. Within a couple hours of powering the RBS20's on, the RBR20 was forced to the latest FW.
I'm an IT tech and have years of experience and training in networking, ethernet and wireless. that is why I did the site survey when I first installed the system and again when the issues cropped up.
Again, this is directly related to FW because with no other changes, the old FW doesn't have a single issue. the latest, which now it updates itself to every time, has constant issues. Very Frustrating
Sep 08, 2021Guru - Experienced User
Possible that your ISP modem/gateway is causing this as well. It's commended that if you have a external router, that the ISP modem, if it has a built in router, be bridged. If not, try setting the RBRs IP address it gets from the gateway router into it's DMZ.
Another configuration to try is to leave the modem in router mode and change the RBR to AP mode and see if the problem continues or not.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can downgrade FW as well to last working version that worked for you on the Orbi system.
- 5ft24daveSep 08, 2021Aspirant
this config has worked for almost 2 years without any issue except the original dropping of network connections when I upgraded the fw. since then, when I rolled the FW back, it has had zero issues.
when I load the earlier FW the issues are gone, however, as I said, within an hour or 2 of rolling the satellite and RBR20 firmware back to working versions, the system AUTOMATICALLY updates the FW to the latest version again, and I can tell because I start getting the dropped connections again. so if you have a way to keep it from automatically upgrading the FW, please let me know because the FW is the issue.
Also, as I said, and it appears my post got skimmed over and not completely read, the Wifi on the Cable modem has always been disabled.
for emphasis, it works as it should on the older FW, it upgrades itself without notifying or prompting me. if I could block that action, I would have a working nnetwork again
What really bothers me is Netgear dismisses this as user error, yet there are a BUNCH of posts here with similar issues, and on quite a few other forums and groups I am on, there are MANY posts with the same exact issues. Netgear support doesn't care, and refuses to look into the issue. at work, I have a MAJOR influence on purchasing, and even though the only netgear products we use are 24 port Gigabit switches, I am going to recommend that we stop purchasing from a company that doesnt care about their customers. We may pay a little more, but the Cisco switches, managed and un managed, don't have issues and if something crops up, the Cisco support is swift and effective
- FURRYe38Sep 08, 2021Guru - Experienced User
Disabling wifi on the ISP router doesn't mean that the router portion of the modem is disabled which can cause problems.
Gave you some suggestions to see if it helps, try them, revert FW, factory reset and setup from scratch.
You can block the updates on your ISP modem if you revert FW:
Add the following key words:
http.fw.updates1.netgear.comupdates1.netgear.com
- 5ft24daveSep 09, 2021Aspirant
Put Cable Modem in Bridge mode last night. Added the sites you listed and update.netgear.com in the blocked sites (keywords won't accept the periods) verified on chrome that the sites were indeed blocked. flashed the older firmware, satellites first then router, factory reset and manually configured everything.
all working good.
when I went to bed, 3 hours later, firmware was still the older version, so confident all was good.
This morning, My laptop has no network connection.. disabled and enabled the network and it connected. same with my ethernet connected desktop. logged into the RBR20, and its the latest FW again on it and the 2 RBS20 satellites. niot sure what its using for the download, whether its going by IP and not by host name or if there is another site address the FW is using. If I could use Tomato or Openwrt for the router and satellites, I would...
