Nufernandes
May 12, 2022Aspirant
RBR20 no ethernet
My RBR20 ethernet port has stopped working. what other router (upgraded) can i purchase to replace it and will work with my current satellites? CBR40 & RBS40V, or can i only use another RBR20?
You could use a RBR20, RBR40, RBR50
They'd all work.
All the ethernet ports quite working on your rbr? Just the wan port? just the lan port?
Did you try a different cable?
Different pc?
are you able to log into the router and check its wan/lan port statistics
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
- NufernandesAspirant
Just the Lan port quit working. it has internet, and all the satellites work and everything works wirelessly, but no output from he LAN side on the router.
the RBR20 only has the 2 ports, 1-Wan and 1-lan
connected a different laptop directly to the router and get nothing
I'd take a little light/magnifying glass and take a look at the pins in the port. I've seen them bent and not work
