firegaranger
Sep 25, 2022Aspirant
RBR20 no internet on guest wifi
I'm having trouble with internet on my guest wifi. It stopped getting internet after I changed some wifi settings.
I've tried factory resetting, downgrading and upgrading fw.
Does anyone have an idea what I can do?
Current Orbi:
RBR20
2 RBW30
- MarkRamosAspirant
I am same issue. Having keeps losing internet connection since update As soon as I did the update, I notice that my wifi will say not connected once or twice a day. I have to hard reboot and it's fine. Anyone experience this issue?
- KevinLiTNETGEAR Moderator
Hello firegaranger,
Welcome to the NETGEAR Community!
Which settings did you change on your RBR20?
Best,
Kevin
Community Team
- firegarangerAspirantDaisy Chain Topology: Disabled
MU-MIMO: Enabled
Implicit Beam-forming: Disabled
Fast Roaming: Disabled
UPnP: Enabled
WMM (WiFi Multimedia): Enabled
Enable 20/40Mhz Coexistence: Disabled- KevinLiTNETGEAR Moderator
Hello firegaranger,
Please navigate to the following settings from the Orbilogin.com page:
- BASIC> Guest Network.
Is the setting "Enable Guest Network" selected?
Best,
Kevin
Community Team
