firegaranger
Sep 25, 2022Aspirant
RBR20 no internet on guest wifi
I'm having trouble with internet on my guest wifi. It stopped getting internet after I changed some wifi settings. I've tried factory resetting, downgrading and upgrading fw. Does anyone have an id...
KevinLiT
Sep 26, 2022NETGEAR Moderator
Hello firegaranger,
Welcome to the NETGEAR Community!
Which settings did you change on your RBR20?
Best,
Kevin
Community Team
- firegarangerSep 26, 2022AspirantDaisy Chain Topology: Disabled
MU-MIMO: Enabled
Implicit Beam-forming: Disabled
Fast Roaming: Disabled
UPnP: Enabled
WMM (WiFi Multimedia): Enabled
Enable 20/40Mhz Coexistence: Disabled- KevinLiTSep 26, 2022NETGEAR Moderator
Hello firegaranger,
Please navigate to the following settings from the Orbilogin.com page:
- BASIC> Guest Network.
Is the setting "Enable Guest Network" selected?
Best,
Kevin
Community Team
- firegarangerSep 26, 2022AspirantYep
