Jenn1949
Dec 17, 2019Aspirant
RBR20 no sync satellite
My RBR20 router will not sync with RBX33 plug in satellite Tech support for over and hour Please advise on if compatibility issue or bad satellite Thank you for your help
Dec 17, 2019Guru - Experienced User
What FW version do you have on the RBR and the RBW? If you can access the RBWs web page. Possible that the RBWs FW is out of date or out of sync and needs to be updated? Did NG discuss this with you?
- Jenn1949Dec 17, 2019AspirantThank you but you are dealing with a MeMe
What is FW?
And how do I go to a website?
Thank you
Also received offer to purchase Pro warranty but every time I click on it, I go to Netgear with no info on purchasing the warranty.
Do I need to call. Netgear as I only have one more day to accept this offer
Thank w- FURRYe38Dec 17, 2019Guru - Experienced User
FW=Firmware
Log into the RBRs web page with a PC or laptop wire or wireless connected to the RBR. Navigate to orbilogin.com or 192.168.1.1
Yes you'll need to contact NG support for warranty help.
Have a joyous Christmas season with family and friends
