philaer
Sep 07, 2022Aspirant
RBR20 not receiving VPN connection
Hello everyone,
i'm trying to setup a vpn connection to access the network when I'm outside home. I followed the instructions provided in different posts: i configured and activated a dns (noip service) and activated the VPN, installed open vpn on my computer but the connection is never made. Specifically:
- my orbi system (RBR20, firmware V2.7.3.22, router mode) is connected to a modem which is provided by my ISP. I already set up this modem in bridge mode, disabling wifi.
- on the orbi logs, when attempting to connect through VPN, i do not see any voice related to VPN (failed connection or similar)
- the DNS is working, the status page on the orbi router is successful, and on the openvpn (verbose to 1) I can see that the ip is correctly resolved (the IP indicated is coherent with what I see on sites that provide the IP used
I have the log from OpenVPN:
2022-09-07 10:50:06 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
2022-09-07 10:50:06 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-128-CBC' to --data-ciphers or change --cipher 'AES-128-CBC' to --data-ciphers-fallback 'AES-128-CBC' to silence this warning.
2022-09-07 10:50:06 OpenVPN 2.5.7 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on May 27 2022
2022-09-07 10:50:06 Windows version 6.1 (Windows 7) 64bit
2022-09-07 10:50:06 library versions: OpenSSL 1.1.1o 3 May 2022, LZO 2.10
2022-09-07 10:50:07 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
could someone point me where is the error?
thanks
- I have tried to change to tcp, but without success. The openvpn client starts as before, and the connection to the orb is never made.
So I have set up port forwarding, dmz, bridge mode but it looks that the ports are always closed: at least, trying from services on internet to check the status, it appears that none of the changes I make are working.
I’m starting to suspect that my ISP is blocking all ports, since I am using not a “regular” service but a wireless one (through telephone networks) because there was no coverage in my area for other tecnologies..
How is the computer (Windows?) connected to the internet when the VPN connection is attempted?
- To the Orbi LAN?
- On another network (coffee shop? friend's house?)
- To a Hot Spot from a cell phone?
- philaerAspirantThe computer is a Windows 7 laptop, I have tried with the hotspot from a cell phone
Cell phone Hot Spot is how I test my OpenVPN setup. Could you verify that the client.ovpn file looks like this:
client dev tap proto udp dev-node NETGEAR-VPN remote *******.mynetgear.com 12974 resolv-retry infinite nobind persist-key persist-tun ca ca.crt cert client.crt key client.key cipher AES-128-CBC comp-lzo verb 0 sndbuf 393216 rcvbuf 393216 route-method exe
