AverageCanadian
Feb 11, 2021Aspirant
RBR20 not showing connected devices
Running RBR20 with an attached RBS20 both on firmware V2.6.2.104 This has been an ongoing issue for at least the last 3 firmware updates where after the update all my devices will show for about ...
vajim
Feb 12, 2021Master
AverageCanadian wrote:Running RBR20 with an attached RBS20 both on firmware V2.6.2.104
This has been an ongoing issue for at least the last 3 firmware updates where after the update all my devices will show for about 24 hours. After that time period I'll be left with only seeing 5-7 devices attached. The app shows the same 5-7 devices.
All my devices not showing as connected devices still have Internet access.
Is there a stable firmware I can dowgrade to that actually works?
I've seen similar using the PC login. I don't recommmend the app, lots of problems. I'd don't think it's related to any particular firmware for mine is different than yours.
I did reboot the modem. router, and sats, and that fixed it for a few hours, then the problem came back. Something must be going on with the netgear servers or something. I gave up. I'm not big on staring at a device list. As long as my devices work (and they do), I'm good.
- AverageCanadianFeb 12, 2021Aspirant
Normally as long as long as they work I'm good, but a lot of the devices on my list are iot devices and I'm doing some automations with Home Assistant so I want to make srue I reserve the ip's of those devices. Kind of difficult to do when they won't show up in any list.
While trying to fix this, I've seen complaints dating back to at least the beginning of 2020. It's just a bit upsetting to see such a basic feature somehow continue to be a issues for this system.
Oh well, guess that's just part of the Netgear life...
