Randycsmith1953
Jan 28, 2022Follower
RBR20 Orbi 34
I apparently have forgotten the password to my router. I have all of my passwords saved in a password-protected file but the password does not work. I recently purchased a smart bed and trying to c...
Jan 28, 2022Guru - Experienced User
Password to the wifi?
Password to log into the gui? Which did you loose?
You can try using the password recovery if its the admin password (and you setup password recovery)
