phidgety
Jan 26, 2020Aspirant
RBR20 ORBI AC2200 - connected, but in "Settings" it says there's no IP address
I'm using an iMac. Just got a new Orbi to replace my dead Nighthawk, installation was a snap — both the base, satellite, and my printer are connected, but in "Settings" > "Network" while it shows...
- Jan 26, 2020
Can you take a screen shot and post it?
Otherwise, "everything works"?
CrimpOn
Jan 26, 2020Guru - Experienced User
- phidgetyJan 26, 2020Aspirant
Thanks CrimpOn,
Strangely, when I returned to the "Settings" screen, it no longer mentions a missing IP address, it merely says, "Connected".
I'm amazed at the speed of the community's answers, as well as at the thorough knowledge you all have.
Phill
- phidgetyFeb 02, 2020AspirantI’m sorry, I intended to write saying it turned out my Nighthawk died so I bought an Orbi and it was simple to set up. Now our internet is working great. Thanks for your help.
. - phidgetyFeb 02, 2020AspirantI’m sorry, I intended to write saying it turned out my Nighthawk died so I bought an Orbi and it was simple to set up. Now our internet is working great. Thanks for your help.
