SomebodyInGNV
Aug 20, 2022Guide
RBR20 Orbi guest network doesn't allow special characters?
I'm on firmware V2.7.4.24. I'm using WPA2-PSK security for the wireless network and have been using a password with special characters since I first set it up. I just tried to enable the guest netwo...
CrimpOn
Aug 22, 2022Guru - Experienced User
SomebodyInGNV wrote:
I just tried to enable the guest network for use with IoT appliances, to isolate them from the main network. I set the security to WPA2-PSK but it doesn't allow special characters, not even spaces.
Perhaps it would be helpful to explain which special characters have been tried.
Just now, I changed the guest password on my RBR50, with firmware v2.7.4.24 (latest) to PhantomX to Phantom?
After the frustratingly long reset period, I logged onto the guest network. No problem.
I suspect "something else".
SomebodyInGNV
Aug 22, 2022Guide
My main network password contains spaces and a hyphen. It works fine with WPA2-PSK. I copied and pasted to the guest network, also set to WPA2-PSK. Attempts to apply it fail. A pop-up message says "A passphrase consists of either 8-63 ASCII characters or exactly 64 hex digits. A hex digit is one of these characters: 0, 1, 2, …, 8, 9, A, B, C, D, E F." I also tried typing the same password in case copy/paste somehow introduces a problem. That didn't work, either.
